Cleco'd Aft Side of Forward Top Boot Cowl Skin To Panel Frame
Cleo'd aft Side of Top Side Boot Cowl Skins to Panel Frames
Modified on Boot Cowl Spacer Strip to 30"
Started installing Elevator trim servo wire to run through fuselage Frame.
Started maufacturing mounting plates for the ADSB and Transponder Antenna
Called Mark Pringle at RMK about ordering up our Dynon Skyview system. He is to send us a Battery box for the new Lithium battery.
Called Stewart Systems and ordered another quart of Primer. Talked to Dan about a Local guy to paint the plane. He recommended Ken at Kalispell Air Repair, 406-756-0565
Called Ken at Kalispell Air Repair. He said he would love to pint it but he is 2 months out.Told him I'd call him back.
Removed the Aileron cables from the left wing and reinstalled the replacements.
