Bob's Web Site
S-20 Raven
Text Manual 01A-01
Main Gear fit up
Finished the Main gear fit up.
Had to manufacture new bushings as the ones from the factory were too short. Drilled and filed our clamp plates to get the bolts to fit properly.
Both gear have a tight fit both fore and aft and top and bottom. Will need to check for the proper camber after the gear is mounted and engine too.
S-20 Raven Home
1363
Avionics Panel
Covering
Fuel Trailer
336
Rans S-20 Kit
210
