Bob's Web Site
S-20 Raven
Text Manual 01-02
Installed Side Formers, ELT and COM Antenna plates
Installed the side formers. Already had the tubes sized and cut but removed them to paint the fuselage.
Installed the ELT and COM Antenna mount plates as per manual instructions. Drilled the ELT mount tray tangs to #11
Fitted the baggage window trim panel to outside of frame. Will install after finish painting the frame.
S-20 Raven Home
1363
Avionics Panel
Covering
Fuel Trailer
336
Rans S-20 Kit
210
