Brief Description: Fuel tank and Leading edge tip wrap
Installed the lower sight gauge fittings inside the rib root. up to and including the Internal Thread Elbow.
Riveted lower root skin to the Root and #2 Ribs on both wings.
Leading edge tip wrap was pre fit by temporarily cleoing leading edge wrap and stringer to wing.
Slipped the tip wrap under the Leading Edge Wrap and positioned.
Had previously dimpled the Wrap and the stringer but made the stringer very bent so again dimpled this time on the wing by staring at one end and working our way out dimpling both the wrap and stringer simultaneously. This straigtened out the stringer considerably.
