Bob's Web Site
S-20 Raven
Text 05-03 & 04
Wing spar assembly
Installed Trailing edge root fittings.
Put the Compression Tube Doubler inside the Bell Crank Compression Tube so the hole aligns with the aft hole Compression tube.
Installed both the Flap and Bell Crank Compression Tubes in the wing Frame.
Installed the Jury Strut Bracket to the forward bolt retaining the flap compression tube.
Assembled the teleflex retainer and the cable guide to the flap compression tube.
Slide Bell Crank Braces into position as per the parts manual.
Remove all clecos and deburr parts. Re-install Braces with clecos. Removed one cleco at a time and riveted.
S-20 Raven Home
1363
Avionics Panel
Covering
Fuel Trailer
336
Rans S-20 Kit
210
