Received new HS front spart parts with wing kit. This spar was redone due to the major problems I had with riveting the length 9 and 10 rivets. I now know that the rivet gun air pressure was much to low to drive these. At low pressure an excessive number of hits is required causing the rivets to work harden and the heads became quite deformed. The redo went well for this critical part.
