Brendons Kit Log
RV-10
Doors
2-9-2018
Started Right Door
Did initial trim of right side door. Matched drilled holes from fuselage into doors. Checked fit. Sanded inside surfaces to prepare for bonding.
Drilled temporary cleco holes, installed strut brace. Left overnight for epoxy to cure.
Re-installed rib into right wing tip. Sanded flox level. Added additional epoxy at leading edge for strength.
RV-10 Home
1672
Aileron
Doors
Elevator
Finishing
Firewall
Flaps
Fuel Tanks
461
HS
Inspection
Moving
Panel
Practice
Tailcone
VS
Windows
Wing - LEFT
Wing - RIGHT
