Decided to install a stainless sheet on belly of forward fuselage with 1/8" fiberfrax sandwiched in. Sheet is approx 2 x 2 except were it is trimmed to follow fuselage structure. This is to keep tunnel temps down. Sheel is to be held in place with closed end rivets. The edges will be sealed with 3M Fire Barrier 2000. The belly will be primed before closing. Rivet locations were verfied to avoid hitting structure.
