Installed nutplates on baggage area bulkhead - plans 33-10. Cut right wintip to fix alignment with flaps, ailerons. Drilled out firewall cable pass-throughs to 15/32" to clear cable collars. Temporarily bolted cabin top to fuse to facilitate door work. Vaccuumed out fuse. Installed bowden cable grommet on firewall for alternate air cable. Installed rubber grommets in side channels for wiring runs.
