Brief Description: Cut Holes for Fans, Install Front Heat Vent, Insta
Cut holes in upper fwd fuselage for avionics/defog fans. Install front heat vent tee with screws. This makes it removable in case brake lines need to be replaced or serviced. Install wire pass throughs in firewall.
