Decided to install control panel under pilot side flap tube cover. Control + power wires from panel will be ran to this point. It is centrally located to easily route wing and tail wires to board. Drilled holes into structure. Tapped holes for 3mm screw Used nylon M3 PCB standoffs in tapped holes Secured board to standoffs using M3 nylon screws.
