Brief Description: Leak check left tank, dimple right tank skin
Fill with water and leak check left fuel tank. NOTES from leak check: The only leaks that were found were at the patches used to cover tooling holes in inboard and outboard ribs. These should have been pressed down better to get a good seal and covered with pro-seal internally and externally. This check was done to make sure there were no obvious leaks before the back baffle was installed. This ensured fixes could be done easily while the tank was still open.
