Brendons Kit Log
Date:  3-12-2013
Manual Reference:  11-7
Brief Description:  VS Attach
Install VS with temporary hardware.
Install rudder hardware and check rudder travel.
NOTE: The rolled leading edge of the rudder was contacting a rivet on the VS. This spot was marked on the rudder. The rivet was driven slightly more in an attempt to clear the rudder. This will be check again on the final rudder installation. The rolled leading edge may be shaped a little better or the rudder bearings extended by one turn.
Fabricated trim bellcrank and trim cable anchor brackets.
Trim brackets
Trim brackets
