Sanded a little of the fiberglass on the lower left of the windscreen. Decided to trim the fiberglass that runs over the canopy. Although I may trim more, now I left it with approximately 1 1/2" overlap. First marked it out and drew a line as straight as I could. Then used the Dremel to cut the fiberglass where marked. Overall I'm pretty happy with the result. The underside of the overlap is rough and shows the multiple layers of fiberglass and where I sanded through in the first couple layers to get it even before adding the next several layers over it. I will have to apply some micro and even it all out.
