Did some more sanding. Opened canopy again, replaced some electrical tape and reapplied mold release. Cut out more fiberglass for the lower rear corners of the windscreen and applied with resin. Applied one more layer of fiberglass around the base of the windscreen and two more layers going over the top. Hoping this is the last layers but will know more when I trim the fiberglass the goes over the canopy. Worked on the cowling a little bit. The fit around the engine cooling intakes doesn't fit very well. Did some sanding and then applied several layers of fiberglass on the left upper cowl at the front 5 inches or so to build it up to match the lower cowl at the intake. Also did the same on the left upper cowl at the outside of the intake but to a lesser degree. Added a fiberglass strip to the inside of the intakes to create a foundation to buildup the edge of the cowl so it fits better.
