Brief Description: Sanded, applied layer of fiberglass
Sanded the layer of fiberglass I put on yesterday to try and make a smoother more aesthetically appealing form prior to adding any more layers of fiberglass. Applied another course of fiberglass. Used pigment around the front because of sanding through the bottom layer of fiberglass at the overlap of the windscreen in about a one inch area. Sanded through it the other day after the first fiberglass was laid in but needed to even out everything so it would look nice. Had lots of trouble tonight making the bottom curves from the front to the sides on both sides. Not super happy but it will be okay. The white areas in the pictures below are where I applied the epoxy/micro.
