Joe cam over and helped me drill the lower holes in the 791's which need to be held on the inside with a block of wood while I held the side skirts and drilled the holes. Went pretty fast and well. He left after that.
Used the Dremel and removed excess fiberglass from the air scoop intake area and sanded down to a nice form. Looks okay, will probably add more fiberglass on the inside (outside of tube inside the cowl) to strengthen the tube attachment to the cowl. Have a spot on the 7-8 o'clock of the intake that is too wide (see photo) so I mixed up some SuperFil and put some in to shape better.
Sanded down the SuperFil I put on yesterday and applied some more.
Prepared the side skirts and the 791's for priming and primed with SEM self-etching primer that I've used before but haven't done any primimg for a long time.
