Got it!!!!! Made minor tweaks to the rear bow on the left side to get proper clearance to side skin. Had slight twist in rear bow relative to the front bow which I was able to get out. Cut front bow tubing to get approximately 3/8" measurement relative to roll bar. Took 3 separate cuts to get right. Once I got the bows fitting properly I put the proper bends to accomodate the plexiglass spread that will occur when attached. Looks pretty good, I'm happy. Now on to the "big cut"!!!
