Brief Description: Drilled holes in firewall for F7108
Cut reliefs in F7105B subpanels to make clearance for vent tubing. Located and measured for holes in F7108 to attach to firewall. Drilled hole in F7108B angle to firewall angle and clecoed in. Checked alignment and temporarily removed F7108 to drill holes in firewall. Drilled holes in firewall firstand then clamped F7108 rib in and back drilled rib holes through firewall holes. Clecoed in place.
