Mounted the the brake fluid resevoir. Drilled holes where brake line fitting passes through gear weldment. Relaized I plumbed fuel lines through top snap bushings in F982 and F983. Sent email to Van's to ask if I can e it that way or need to reroute. Clamped horizontal stabilizer onto fuselage after filing skins where they meet the fuselage on the bottom.
