Brief Description: Fuel Valve Cover and Plate, Flap actuator
Riveted nutplates onto F983A fuel valve plate, deburred and screwed onto bulkhead. Fit F983C and deburred. Finished riveting rivets on F601K that were left open until now. Clecoed on F601K and drilled holes from F982C to it. Removed and installed nutplates. Clecoed 601K back in and put screws in. Even though I'm using electirc elevator trim I left triangular flange on F983A until later in case I found a use for it. Drilled and reamed to size holes in WD-613-EF flap actuator clevis ends. Cut F680 block to size and trimmed slot as indicated in plans. Drilled holes in F680 but did not cut it in half yet.
