Finished layout of F652 baggage bukhead, Drilled holes for #8 screws. Cut notches in bottom for shoulder harness cable pass through. Cut 8.5 inch radius at top of bulkhead on both sides. Clecoed F751 and F652 onto F706 and drilled all holes including those on the 728. Removed bulkheads. Drilled holes in wear blocks and notched per plans. Located blocks on bulkheads and drilled holes. Fabricated the 8 pieces from sheet metal used on wear blocks. Deburred bulkheads. Riveted wear blocks onto bulkheads. Clecoed on steps and attached to rib with bolts. Riveted on steps.
