Brief Description: Riveted, worked on 718 longerons
Riveted outside row of rivets on the F623's to the bottom skin. Countersunk holes in both F718 longerons. Filed open slots where 718's pass through F706, 707, and 708 bulkheads to make it fit a little better. Clecoed in 718's. Drilled hole in F904B for conduit to run through, basically just opened existing hole made before to larger diameter.
