BRUCE'S WEB SITE
Date:  3-29-2008
Number of Hours:  4.00
Manual Reference:  8-9
Brief Description:  Locate rudder pedals in fuselage
Drilled holes in F6116 and F6115 Bearing Blocks. Attached F6116 side bearing blocks onto rudder pedal assemblies and dropped into fuselage for drilling. Measured per plans and also measured additional locations for adjustment of pedal length. Also attached center F6115 bearing block temporarily while working on the F6118 brace. Trimmed brace per plans. Attached the brace to the center block and clamped brace to F601 stiffener. Drilled holes for brace to stiffener. Drilled all holes for rudder pedal assemblies and removed from fuselage.
