Had to redo the throttle and mixture cables, as well as the carb heat cable because I forgot to pass them through the heater box cover plate. Hate it when I have to redo things. Also, drilled the holes in the cover plate, firewall, and panel subassembly the controls are on for the filter bypass control cable and installed that. Put some additional spiral wrap on the wires throught the cockpit where the pass by the fuel selector and lines prior to going throught the spar to prevent scuffing of the wiring. Reinstalled cockpit panels over the flap motor, baggage compartment side panels which I had to clearance for wires and pitot and AOA lines. Also put cover over center forward cockpit area which also includes the heater box area. Before all this was done I thoroughly vacuumed out everything to get it clean.
