Installed network wiring between VP-400 Display Unit and PDU 1. Powered up VP-400 which comes on with the Master switch and used Configurator from the iPad to put in settings. Once setting were all in I tested a couple switches. When Mastter comes on I have the P-Mags powered and they worked as well. I turned on the Boost Pump switch and it worked as well. I turned on the Avionics switch which powered up the Skyview system and the CO Monitor. Voltage only read 11.4 on the CO Monitor so I connected up the battery charger and called it a day. The backup battery annunciators on the Skyview displays both say the batteries are low. I'm gonig to have to look into the charging of these since it is my understanding at this point that they only charge when the alternator is running.
