Discovered that I had soldered the stick grips wrong because of the Vertical Power setup. Re-worked the pilot grip which eliminated several wires and three from exiting the grip through the stick. Screwed the pilot grip together and attached to the stick. Drilled a hole for attaching to the stick and installed a screw. Soldered the wires for the PTT on the co-pilot grip, the only thing which will be active on that grip. Screwed the grip together and installed on the stick, again drilling a hole for a screw to hold the grip to the stick.
