Spent some time testing and labeling all wires coming from 37 pin connector from EMS module. Wired up the primer pump but left power end unterminated. Ground wired terminated at ground block. Spent some time getting routing of all wires on right side of engine in their approximate locations. Added an adel clamp at the aft right hand baffle to route EGT wires. Removed Pmags and attached the 1/8" tubes with clamps and placed back on engine but nuts not torqued down. routed tubing to tee fitting which was then routed to barbed adapter fitting on VA-168 block. Determined location for manifold pressure module and drilled holes and attached to the firewall. Screwed 1/4" barbed adapter fitting into the VA-168 and ran 1/4" tubing from the fitting to the manifold pressure module.
