BRUCE'S WEB SITE
Date:  4-7-2012
Number of Hours:  4.00
Brief Description:  Removed studs, installed fittings, gear on P-Mag
Removed long studs on left side of engine which held magneto in place. Have to install shorter studs because P-Mag doesn't require the spacer which I also removed. Installed drive gear on P-Mag and torqued to 175 inch pounds and installed cotter pin. Torqued nut for drive gear on oh P-Mag as well. Installed oil pressure line fitting on engine. Installed oil line to cooler fitting on engine. Installed fuel pump cooling shroud which required taking out allen head bolts and putting them through the shroud. Tightened bolts after applying locktite and safety wired. Bolted on engine mount but did not torque nuts yet. Installed front gear leg and bolted on per plans.
Oil pressure fitting
Fuel pump cooling shroud
Engine mount and gear on
