Fabricated hard points for magnetometer install. Dynon was installed on CP side and mounted in the same roll, yaw, and pitch axis as the Dynon EFIS in the panel. (The Dynon, like the panel, has about a 4deg forward tilt). The GRT's were installed to match the roll,yaw, and pitch of the AHRS on the canard. Mounds of cabo and micro were used for leveling hardpoints.
