Cleaned up wings. Jeff B primed wings and fuselage with a heavy coat of yellow prime. Filled remaining pinholes in wings with Nitro Stan. Left nitro without sanding (will wet sand later), and put wings in storage. Cleaned up doors.
Fabricated and installed bulkhead with access hole between main spar and outboard fuel bulkhead. Used 2 bid.
Final prime
Final prime
Bulkhead between main spar and outer fuel bulkhead
