Brief Description: Seat belts, roll servo, gear swing
Completed seat belt installation. Reinstalled roll servo and ELT. Tweeked roll servo tie rod for better operation. Cycled gear several times. Tweek adjustment of both pump pressure switches. Good operation. Worked on throttle position gear warning switch. No way I can use micro switches provided. Have to find one with a longer actuating arm.
Located position on upper cown for oil service door using 2 marked strings.
