Dug out Cabo below aft locking pin for both doors. The pilot door required removal of about 1/2 inch of steel receptical for door pin. This cavity was required to accept the arm of the "door open" micro switch. Fabricated a pad of cabo on which to mount the micro switches.
Decided to complete the glassing of the entire length of the tube on the back seat back. Did so with 1 bid and micro.
Opened holes for P/CP seat back hinge bolts.
Worked on determining mounting of AveoMaxx Landing light within the supplied mounting part.
