Brookes Web Site
Date:  2-16-2011
Number of Hours:  7.00
Brief Description:  Fuel Shutoff Valve
Worked on Fuel shutoff cable installation. Bent and fabricated bracket for cable handle which is mounted on the fuselage wall directly under the Mixture control. Cable is a push to release type. Valve handle modified with a shorter handle 90 deg extention to allow for valve to operate with push/pull cable along its longtitudinal axis. Geometry is such that 3 inches of linear travel results in full valve motion from fully closed to fully open. Drilled hole in shank of AN3 under head for cable to be attached.
Bracket for Fuel SO cable
Modified Fuel SO valve
SO valve in place
SO valve in place
Copyright © 2001-2017 Matronics. All Rights Reserved.
