Fit fuel sender. Switched out AN3-10 for the supplied AN3-11. Added 8-32 nuts behind for more thread area. Will use thick washer on top.
Used fast West epoxy to mount hard points and sender flange. Set up too fast. Will finish tomorrow. Partially glassed in long longtitudinal baffel and slanted bulkhead aft of strake baggage area.
Cut 2 1/2 in mouseholes in top and bottom of baffles
