Brookes Web Site
Date:  2-17-2010
Number of Hours:  8.00
Manual Reference:  9.3.1
Brief Description:  Cutting and installing copilot wheelwell
Finished cutting and fitting copilot wheel well to fit wheel. Made form with 1/2 inch foam for top, added release tape and glassed with 7 Bid. Built inner flange for pilot forward bulkhead. Cut fuselage to more approximate actual size of baggage compartment opening. Note the notch left for the wood block left to position upper strake correctlty.
Putting release tape on foam form
Glassed and peel plyed
Flange curing inside forward bulkhead
Copyright © 2001-2018 Matronics. All Rights Reserved.
