Cut another "F" baffle form previously glassed divinicel due to the change of shape requireing the triangular piece over the wheel well. Fitted this piece in. Fitted "G" baffle to line up with "F" baffle. Decided on final configuration of strake baggage area. See Image 2 below for the layout. Will have a bulkhead angled from the lower strake to intersect with the upper strake at the fuselage. This should provide adequate armrest and storage area. In addition there is plenty of room (about 9 inches) to install a glass window in lower strake. Estimate the slanted bulkhead will allow for 4-5 gal of additional fuel/side
