Brief Description: Permanent hardware in gear retraction system
Installed permanent hardware in gear retraction linkages. Installed fittings and brake line on brake cylinders. Started running conduit for rudder cable and brake lines. I decided to use conduit for the brake lines like I did down the gear leg (soda straws from Wendy's). The conduit will run from the left pedal down and along side the rudder pedal conduit.......from the right pedal on the copilot side. Brake line will continue through the gear bulkhead to the gear leg. I used 1/4 inch poly tubing inside the straws to give them rigidity. After glassing, tubing will be removed leaving only the straws under glass.
