Install hard points into fuselage wall. Plans said to use 5 min epoxy, but I had a hard time with that setting up too fast. After several tries, I was able to use it to set the hard points in place sufficiently to remove the gold box. I then filled in the hard point cavity with micro and cabo and glassed over with 2 BID and peel ply. Let cure overnight and installed gold box. It looks nice!
