Brief Description: Locating position for MG pulley system
Used a threaded rod screwed into MG hydraulic cylinder shaft to locate mounting position for MG pulley system. Used rod to project the shaft onto the gear bulkhead. This projuction point was used to determine the position of th pulleys so as to get a straight a pull as possible from the MG cylinder to the pulleys.
