Brookes Web Site
Date:  5-1-2011
Number of Hours:  8.00
Brief Description:  Cowling, Nose cover
Cleaned up yesterday's work. Drilled 1/8" holes as before and trimmed flange to 1.5".
Fabricated a 5 bid flange attached to upper cowl for a cowl-to-cowl flange.
Started with nose cover. Sanded a paint stick to form a lengthwise wedge. Hot glued this under the aft opening of the nose cover. Fabricated a 5 bid flange to the nose cover onto the wedge installed earlier. This "wedge" is intended to make removal and replacement of the nose compartment easier.
Upper and lower flanges
cowling to cowling flange
Flange inside nose cover
