Brookes Web Site
Date:  12-22-2010
Number of Hours:  6.00
Brief Description:  Install Prop Governor
Installed the prop governor bracket under the cylindert 4-6 crankcase mounting bolts. While tightening bolts, I noted that BOTH bolts would simply spin and not tighten. That is not a good thing. I pulled off the engine mount and found that both case bolt threads had been stripped clean. See photo. I obtained some helicoils, drilled, tapped and installed helicoils. Replaced engine mount with prop governor attached.
Helicoils in engine mount holes
Stripped thread from case
Copyright © 2001-2018 Matronics. All Rights Reserved.
