Brookes Web Site
Date:  12-6-2010
Number of Hours:  7.00
Manual Reference:  12.2.4
Brief Description:  Engine Fuel/Pressure lines
Finished installing fuel pressure line from the spider, under plenum on pilot side, up engine mounting strut to firewall to mainfold. Obtained hardware for bringing manifold pressure inside of cockpit. Used a 1 1/2 inch 1/8 NPT stub to a "t" then connected a 1/8 " and a 3/16 " barb fitting to either side of "t".
Plans called for a 45 deg steel fitting into the Manifold Pressure port on intake manifold. I could not get this to work. Need a 90 deg steel fitting. I temporarily installed a 90 deg aluminum fitting in order to fabricate the manifold pressure line.
Fuel press/Oil press/Manf press manifold
