Brookes Web Site
Date:  12-1-2010
Number of Hours:  7.50
Manual Reference:  12.2.3
Brief Description:  Throttle bracket and drain lines
Made some steel spacers for the throttle shaft. Installed spacers to keep tie rod ends of thotttle cables in place. Gear micro switch not installed but provisions are made for it. Fabricated 1/4 inch aluminum drain lines that attach to the TCM provided drain manifold for each cylinder. Brought drain lines together at firewall side of engine with a 3 way AN flair fitting. Attached auto fuel line to fitting and brought to firewall. Attached rubber auto fuel lines to barbed drain fittings at spider and mechanical fuel pump.
Started tightening up preoiler fittings. Will have to remove preoiler in order to tighten properly.
Throttle Cable bracket
Throttle cable bracket from CP side
Cylinder drain lines
