Finally getting to it. Worked on installing lower airleron torque tube. The majority of time was just trying to figure the installation out and to avoid mistakes. I bolted the lower torque tube to the front mounting bracket with AN2-7A bolt and associated nut and washers. Temporarily installed tube in keel for fit. Removed and cut tube with hacksaw to the proper length for installation later. Could not assemble push rod between lower and upper aileron torque tubes due to missing hardware. Ordered the hardware from Velocity today.
