Continued to fit and shape panel. Decided not to provide separate "subpanels" for throttles. After discussions with Jason of Aerotronics, will let Aerotronics provide for the T/P/M installation. Extended the mid support of the panel with 11 Bid and a Scharf joint. Reinforced the bottom of the panel with 1 x 3/16 aluminum stock. Attached with epoxy/flox/cabo mixture. Marked hard points for pilot seat per manual instructions. More analysis to be done to determine location.
Bondoed in a wooden support inside of leading tip of strakes over doors in order to allow it to maintain it's shape after cutting off (in the future).
