Attached upper and lower cowling and worked out a plan to modify cowling to fit airplane. It turns out that I will attach both top and bottom half forward flanges to the fuselage as built. All the modifications will be done aft of this connection. Note the gap on the side between the upper and lower halves resulting from the 2 inch increase in fuselage height.
