Brookes Web Site
Date:  12-29-2010
Number of Hours:  7.00
Brief Description:  Com Panel, Overhead plenum
Fabricated flanges for com panel within cut down portion of keel such that panel is recessed 1 1/2 inch inside. Used 4 bid.
Cut holes in overhead plenum for front seat reading lights and air vents. Reading lights are in the forward slanted part of the plenum. Removed the inside layer of fiberglass and some foam to accomodate the lights.
The AeroComposite prop arrived!
Layup of com panel flanges in keel
Ovhd plenum.  Note excavation of blue foam
The prop arrived!
The prop arrived!
