Brookes Web Site
Date:  10-8-2010
Number of Hours:  11.00
Brief Description:  Plenum and doors
More work on plenum and doors. Also spent about 3 hours trying to bleed brakes. Left one is good. But right is problematic. Tried adding fluid through caliper as well as pumping fluid back out through caliper. Bubbles remained visible in lines especially in the line between the two right brake master cylinders. It acts like there might be an air leak somewhere but there is no fluid leakage evident. Will try another day.
Fitting the plenum
Fitting the plenum
Michael about to launch!
Me
Me
