Brookes Web Site
Date:  9-29-2010
Number of Hours:  9.00
Manual Reference:  9.7.1
Brief Description:  Fuel and vent lines
Installed 1/2-3/8 reducer in "to engine" hard point in sump. Reinstalled sump. Finished 1/2 " fuel line from Copilot tank to sump. Installed 1/2 inch line from sump to engine with a shutoff valve. Positioned shutoff valve so that it can be cable operated with a pull cable to be installed on pilots sidewall. Installed vent lines so that that they made a constant "rise" to the four way manifold while at the same time conserving as much real estate as possible on the firewall for future component installation
Installed new hydraulic lines from pump to canard bulkhead.
Shutoff valve in line to engine
Fuel system so far
Fuel system so far
Copyright © 2001-2018 Matronics. All Rights Reserved.
